Cameras Logo
b
bart lowthe Posted on Jun 02, 2019
I have stuck power button on my Olympus sp500uz camera
Doug
Level 1:
  • Contributor 3 Answers
  • Posted on Jun 04, 2019
 Doug
Contributor
Level 1:
Answers
Questions
0
Helped
1012
Points
13
Sounds like you dropped the camera and the case has split apart ..... remove visible screws, pop the case back together, replace the screws
4 Related Answers
Randy Morton
  • 479 Answers
  • Posted on Aug 22, 2008
SOURCE: Can't download photos from Olympus SP500UZ
it would appear that the computer is seeing the camera incorrectly... the camera should be recognized as usb mass storage device and uses the driver usbstor
caroldon
  • 17130 Answers
  • Posted on Jan 11, 2011
SOURCE: Do you know where I can get a lens cover for an
Please log on to the Official site for support in UK and Ireland for your need.
Click the link below:
http://www.olympus.co.uk/
Post your requirements or call the support for the lens cover availability..
  • 102366 Answers
  • Posted on Jun 23, 2011
SOURCE: will my olympus sp500uz support
According to the Specifications page of the manual, the SP-500 UZ supports xD cards from 128MB to 1GB.
Harrie
  • 6746 Answers
  • Posted on Jan 14, 2015
SOURCE: I have Olympus FE330 and the Power button stuck in the depressed position and it turns the camera on and off.
First you need to get the button out. But if it is defect (I think it is) that won't help. Did you try to find out what is keeping the button in the depressed position? is it possible there is some dirt around the knob? Something you can remove?
I don't think it is worth bringing it to a service center.If they need one hour to repair it will cost twice a new camera of that class.
So when you can't get the know out, I think you should start saving up for a new camera.
OLYMPUS VG120 LENS STUCK
Try removing the camera battery.Press several times on the power button.Re-load battery and power the camera.
Hope it helps.Thanks!
Jan 05, 2012 • Cameras
Need a manual for sp500uz
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1189
2helpful
Will my olympus sp500uz support the new M+ 2gb card?
Do you know where I can get a lens cover for an Olympus sp500uz in Ireland or on internet?
1helpful
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
1helpful
The power button does not turn the camera on.
Your lens is probably damaged or stuck(such as beach sand particles caught in it) and needs to be cleaned out or replaced. Olympus repair shop can do this(olympus site online) or a camera shop. It is also possible that the batteries do not have enough power in them.
1helpful
Lens stuck in the extend position.
The problem you are describing is a problem with a sensor in the lens assembly. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product. The cost is $87 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
1helpful
2answers
Blurry pictuers
First of all, tele-multipliers or tele-converters do not have the greatest optics in the world, and are usually fine for close up images but not much else. Secondly, they do restrict the amount of light coming into the camera which could interfere with the internal metering. Third, you have additional lens surfaces to get dirty. To fix the problem, start with the easy one, and clean all lens surfaces meticulously with a soft lint free cloth. If that doesn't fix it, try shooting non-moving objects in brightly lit areas. If you are still getting blurry pictures, try using the tele-converter on a close-up image within the focal length of the lens combination. If that doesn't work, give the teleconverter to someone you don't like and go buy a good quality 50-135mm zoom lens. Vivitar, Sigma, or other similar lenses are good quality and are very reasonably priced.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
