Question about Generac Electrical Supplies
Generac 14kw Lp mod 0055030 ser 5437842 Battery was dead. Replaced but has code RPM SENSE LOSS.
    Top Expert:
  • Generac Master
  • 30,870 Answers
Join here ask your question. these guys are experts
zillerstore.com/forums/forumdisplay.php?f=3
Posted on Jun 02, 2019
Testimonial: "I have been working through this forum nearly 5 months without actual help. They seem to be sporadic and assume too much. They are the ones who told me to measure the voltage on wire #18 and directed me to the oil pressure sender area where it is not. It seems to me that if (anyone) is expert that there should be no ambiguity in their answer. They directed me to their retail outlet for a service manual only to tell me it is out of print, available only on CD, but won't advise if the CD is the same as the online version, which is all but useless. It's almost like a club, if you don't drink with these guys they don't talk. Just keep making superficial remarks to try and frustrate you into paying for service. I won't bite."
  • 1 more comment
  • STEVE Jun 02, 2019
    its not out of print its right here. https://www.generator-parts.com/manuals/...
    this is the best i can do for ya. good luck
  • cressbenwell Jun 03, 2019
    Thank You! I have looked at it and I believe I will be able to use it. Can't say thank you enough for sending the link to a "real" service manual.
    ben
  • STEVE Jun 03, 2019
    my pleasure ben. good luck
  • Generac Master
  • 1,478 Answers
RPM Sensor Loss 1501
ALARM
This RPM alarm is set when a 2 cylinder unit was already running and stalled or lost the RPM signal from the ignition coils. Possible causes could be a fuel issue, the LP tank is empty, 1 or both ignition coils are damaged, or the unit was overloaded quick enough that the engine stalled and set the alarm.
Possibly a fuel flow issue.
Try running without load for awhile, if it faults with no load then either an ignition module or control board or fuel. If it only faults with significant load, then more likely a fuel flow or engine is stalling from sudden increase in load.
3 Suggested Answers
SOURCE:
emissionwiz
  • 85206 Answers
SOURCE: GENERAC 14kw natural gas generator. Low RPM
I am sorry but you have selected the wrong product category. Please re-post in correct category. Thanks
Posted on Aug 29, 2012
  • 30870 Answers
SOURCE: Generac 14kw Propane generator won't start, just buzzes and displays cranking then RPM sensor loss.
if its not cranking clean your battery terminals and check the charge level. also check battery water levels
Posted on Jul 14, 2018
Jul 14, 2018 | Generac Electrical Supplies
I have a red light and message Stopped-Alarm Overcrank. what could be done
it didnt start after cranking 3 times. its probably time for service and a valve lash adjustment, clean battery terminals etc etc
Apr 19, 2018 | Generac Electrical Supplies
Generac 14kw, overspeed fault
thers a problem with the stepper motor that controls engine speed according to generacs manuals. if you dont have one i suggest if you plan to repair it yourself get one . also join ziller electrics online forum for help
Nov 18, 2017 | Generac Electrical Supplies
WHAT DOES SENSE LOSS MEAN
RPM Sense loss means that the generator controller hasn't received a valid signal from the ignition coils for 3 seconds of attempting to start. Probably a dead or low battery or bad ignition coil. Replace the battery and try again. Call dealer if problem persist.
Aug 20, 2015 | Generac Power Systems Centurion by 16000...
Generac troubleshooting
please send me more info about this generator I need a model number is this a natural gas or propane I have a neighbor that just had one installed I might be able to get some info from him to help you
Aug 30, 2014 | Generac 17 Kw Air-Cooled Standby Generator...
GENERAC 14kw natural gas generator. Low RPM alarm What should should I do to repair.
Aug 29, 2012 | Cars & Trucks
Electrical Supplies Logo
75 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
