You should have two (or more) RCA plugs on the back of the deck that will act as pre-amp outputs for subwoofer and speakers.
Failing that, your wiring harness should have come with a wiring diagram that will let you know which is the subwoofer output.
Failint THAT, the deck itself should have a wiring diagram on the bottom or side telling your which wire is which.
And if that fails, Your deck may not have a subwoofer output. Just attach your sub to the amp pre-out like everyone else.
To wire a DVC subwoofer, treat it (in the diagrams) as two seperate speakers, called coil one and coil two. This makes things easier.
To wire them up, wiring them in series would be safer, but if the amp is 2 ohm stable, put them in parallel. Look up dual voice coil wiring in google imagesfor more information and pictures.
Well for a wiring diagram there isnt one. Really all you need to know is how to wire it properly. You can put it up to 8 ohms and all the way down o 2 ohms and possible 1 ohm. Check this website: http://www.bcae1.com/spkrmlti.htm
Hello ml3ray, you might want to check the following link i actually dont have the wiring diagram for that specific subwoofer if there is any technical support you may need just email me at [email protected] or write back at my fixya profile.
