SOURCE: Leaking carburetor
replace to gaskets on the bowl and usually theres a screw/or spring release on the bottom of the bowl....replace those gaskets as well
SOURCE: replacement carburetor OHH55 tecumseh 5.5 hp rear
Need the 5 numbers and a letter following the model number to tell you that. :)
SOURCE: my tecumseh engine 5hp leaks gas threw the carburetor to the airf
stuck needle valve or bad float in carb.
SOURCE: gas leak out or the carburetor
Thiis usually caused by a failure of either the float valve or the float itself.
Bad float needle valve: If some dirt or other particle gets stuck on the needle valve or seat, the valve will not be able to completely close and fuel will continue to flow into the bowl and eventually overflow. A new needle valve and seat are < $5.00 on-line.
Bad float: If the circular float gets a hole in it, fuel will get inside and the "float" will get heavy and no longer float on top of the fuel in the bowl. Because it doesn't float it will not rise high enough to push the needle up into the seat and keep extra fuel from entering the bowl. A new circular float is < $10 on-line.
