Type wrong passwords for three times its ask for the master password
master password u get from this site http://www.masterpasswordapp.com/
or if it does not work change the bios from chip-level person
SOURCE: need to reset fujitsu lifebook t4220
reset it using this
download this file and burn the image into a cd and boot from it and select the directory where your windows is installed
http://rapidshare.com/files/226200662/cd080802.zip
SOURCE: I have fujitsu siemens lifebook
Hello, all i know that you can do, is to open up the system and bring out the board. Deep it into a salt water for about 20min, then take it out and dry it very well, then couple it back then see if the password will come up again.
SOURCE: Fujitsu LifeBook AH531 screen
It could be the inverter that runs the back light.
Have a look around maybe on Ebay, it's cheaper than a another new screen. Take yours out of the laptop and look for any names or numbers on it to make sure you get the correct one.
Testimonial: "Thanks, Stuart... I didn't know; I will look into it. HL"
SOURCE: Where is the wireless switch located on the Fujitsu Lifebook A series model AH531?
I'm not sure where the switch is but to enable the wireless connection, you could go to the control panel>network and internet, in the left hand menu choose, Change adapter settings, right click on your wireless network connection and click enable.
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
