Hello Walter, what do you want to repair in your Sanyo DC-D37U, the mechanism of the CD player?
I sent you the link to download a Service Bulletin of those mechanisms
I hope you can repair it, comment the results
Greetings Franco Dosil
Hola Walter, que es lo que quieres reparar en tu Sanyo DC-D37U, el mecanismo del reproductor de CD?
Te envio el link para que descargues un Boletin de service de esos mecanismos
Espero puedas repararlo, comenta los resultados
Saludos Franco Dosil
https://www.dtforum.info/index.php?action=dlattach;topic=7137.0;attach=9887
SOURCE: philips cd player
There are several locations that may be able to help.
Sankar Bldngs, Thakaraparambu
east fort
ph: 2468949
Power house road
Ph 2479710
Pulimoodu
Ph 2329368
Mettukada
Ph 2320744
Industrial Electricals
Ph 2557394
SOURCE: DC-D37U
pls Check d cable if there is any broken wires or check the fuse on your audio shelf system
SOURCE: sanyo dc-da2000 cd player starts spinning then stops
if the display on the CD, reads, no disc, then try to clean the CD lensthe best way is with a cotton bud and white spirit or something similar also buy a cheap CD lens clearer kit, in the cheap shops for about a quid, keep putting it into the CD player, it will clean as it goes,
