SOURCE: connecting washing machine to water
One for hot water one for cold.
They both must be hooked up or water will run on the floor.
SOURCE: Can u run hotpoint wmtl79-d/dg washing machine
yes it can be used only on cold water
if what your asking is that if you only have one hose to connect to it that cant be done the water valve where the hoses attach to must be capped off on the hot side or water will leak out of it
so yes only cold be used but must cap off hot side inlet at machine
SOURCE: Hotpoint WMD960 on start says ' no water supply '.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses.
If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
