SOURCE: Trolling motor will not spin with out being turned by hand.
This may sound really dumb but it's worth a shot. I bought a trolling motor and it did the same thing as yours. I put up with it until I broke a prop blade. When I was changing the prop I discovered about fifty feet of monofilament fishing line wrapped around the shaft, partially melted, hidden by the prop hub. Once removed, it worked fine. Hey, try it, can't hurt.
SOURCE: kenmore 80 series washer mod 11024852300 will not spin
pull the motor check the operation of the motor while it is on the floor: this motor reverses to spin; usual problems are; loose conection of motor plug (not snapped in) clutch springs and, piviot points blocked by other parts; clutch brake pads installed wrong or; mis-adjusted; slipping
SOURCE: hi. my ge wjse3110a won.t
The motor is going bad...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: POWER TURNS ON AT THE
If it spins freely when it is not powered then the start capacitor has gone bad and replacing that will fix the problem...
If it does not spin freely and the bearings need oil then check out this tip on how to oil the bearings in the motor...
How to Oil Condenser Fan Motor with pictures
heatman101
