Computers & Internet Logo
A
Adara Lambrou Posted on Jun 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My friend and I ordered one and it came with two different 3-d mixes in it hers worked but mine felt like sand and hers was blue and mine was sandy color as well as texture wise
barrybam
Level 2:
Sergeant:
  • Expert 208 Answers
  • Posted on Jun 03, 2019
barrybam
Expert
Level 2:
Sergeant:
Answers
208
Questions
0
Helped
76763
Points
651
What are you talking about??
1 Related Answer
Anonymous
  • 934 Answers
  • Posted on Nov 04, 2008
SOURCE: mixed colors
Color wheels in that unit were updated to remedy a flaw in their initial manufacturing. I suspect you have one of the updated wheels and now the dmd board is having a problem distinquishing relative speed etc. Pull dmd jumper to fix it. Remove the jumper pin on the dmd board, metal shield has a cut-out so you can just reach in and grab it with a pair of needle nose pliers and pull it out.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Can you tell me where I can find a Manuel for the hyper tough rotary tool accessory kit?
Jill Timm's class, The Amazing Dremel, into one blog post.
Bwahahahahahahah!!!
I did not take into account how many notes I took during the workshop. In fact, my table neighbor at the workshop teased me for two days on how many notes I took.
My plan is to split the information into three blog posts:
Please note that this post only focuses on what the bits look like and what they do. Oh, and the bits mentioned are the only ones that we used in the workshop - we didn't use any routing bits. Sorry.
That said, let's talk Dremel bits.
I think that one of the things that both attracted me and freaked me out about the Dremel was its huge buffet of accessories. The packages are labeled by use, but it still seemed like gibberish to me. Jill created the perfect environment for overcoming my Dremel fear.
You can read about my class in the following blog posts:
This post is in no way meant to replace the total awesomeness of taking Jill Timm's class. I benefited so much from hearing Jill's experiences and seeing her work in person. If I had bought a Dremel and experimented with it on my own, most likely I would have never tried it on the range of materials that we did in class.
Jill recently announced that she's taking her Dremel class on the road and would love to be scheduled by your group. I highly recommend the class if you have a chance to attend.
The main categories of bits, according to Dremel, include the following:
  1. Carving & Engraving
  2. Sanding
  3. Cutting
  4. Grinding & Sharpening
  5. Cleaning & Polishing
These categories are pretty consistent among other manufacturers of rotary tool accessories, so you can often find alternatives if you shop around. Carving & Engraving I used two different types of bits that fall into the carving & engraving category - diamond bits and high speed cutters.
Diamond Dremel bits
Diamond bits can be used with the following materials:
  • Aluminum
  • Bookboard
  • Ceramic tile
  • Glass
  • Mirror
  • Steel
Dremel high speed cutters
High speed cutters can be used with the following materials:
  • Bookboard
  • Linoleum
  • Polymer clay
  • Wood
Sanding Sanding involves two different parts - the drum and the sanding band. Sanding bands come in different grits, just like sheets of sandpaper.
Dremel sanding bands and drum
To use the sanding band, you simply slide it over the drum. Replace it when it wears out. Easy peasy.
Sanding bits can be used with the following materials:
  • Aluminum
  • Bookboard
  • Plexiglass
  • Polymer clay
  • Wood
Cutting There are different types of cutting wheels for different materials.
Abrasive cutting wheels
Abrasive cutting wheels can be used with the following materials:
  • Bookboard
  • Plexiglass
  • Wood
Fiberglass cutting wheel
Fiberglass cutting wheels can be used with the following materials:
  • Aluminum
  • Bookboard
  • Ceramic tile
  • Wood
To use a cutting wheel, you have to attach it a mandrel.
Dremel mandrel
Unscrew the tiny screw on top of the mandrel and remove one of the washers.
Slide the wheel onto the screw, then add the second washer. Attach the screw to the mandrel base and tighten.
Replace the wheel it when it wears out.
Grinding & Sharpening Grinding and sharpening stones are made of two basic materials: silicon carbide (green bits) and aluminum oxide (brown, orange, pink, or grey bits). You may have noticed that some of my grinding stones are oddly-shaped. This is because the stones wear out with use. You can reshape your grinding stones using a dressing stone.
Orange grinding stones
Orange stones can be used with the following materials:
  • Ceramic tile
  • Glass
  • Mirror
  • Steel
Blue/green & pink grinding stones
Blue/green and pink stones can be used with the following materials:
  • Aluminum
  • Ceramic tile
  • Glass
  • Mirror
Cleaning & Polishing Felt polishing wheels and cones are used in combination with polishing compound.
Polishing felts and mandrel
Polishing compound
To use a polishing felt, you have to attach it a mandrel (different from the cutting wheel mandrel). The felt has a tiny hole in the center of it - you screw the mandrel into the hole to attach it.
Felt polishing wheels and cones can be used with the following materials:
  • Aluminum
  • Ceramic tile
  • Glass
  • Mirror
2answers
The mixture of sand and cement for laying bricks
mortar proportions are always expressed as a proportion of cement to lime to sand and always in that order
common mortar made from portland cement has one part cement to one part lime and 6 parts sand ===1:1:6
Cement bags have the mix written on the side for mortar mix or concrete mix or you can get mortar mix cement which already has the lime added
1helpful
What makes sinkholes
There are several different causes,man made or natural
We had one here in Australia due to subsidence into an old mine.
Pipes which leak over a long time can cause this in sandy soil.
Another cause is underground erosion of limestone strata caused by slightly acidic rain or groundwater. There are often associated long caves.
The same thing can happen with ancient lava tubes around old volcanoes
I m having the error 105 sir wat can i do to resolve this???please help me....
HI friend......
> I had the same Problem,
> I have Norton Internet Security installed and it was blocking the
> application. To Fix I did the following:
> 1. Opened Norton Internet Security
> 2. Clicked on Personal Firewall and clicked on Configure
> 3. Clicked on the Programs Tab and scrolled down to Chrome.exe (Mine
> said "Block All")
> 4. Changed it to say "Permit All"
> 5. Opened Chrome and it worked.
hopeyour problem solved
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
1helpful
What is the sand and cement mix ratio for a patio
Hello. The typical volume-ratio for a self-mix concrete in this application would be one part Portland cement to three parts sand. For a stronger pad (capable of higher stress loads) it would be as low as two parts sand, but this is not necessary for a standard patio pour. The gravel should be three parts, more will make it tougher to achieve a smooth finish. Re-cap: Portland cement - 1 part, sand - 2 or 3 parts, gravel - 3 parts. Hope this helped.
Apr 12, 2011 • Garden
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
2helpful
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
(3.2 v6)odometer not working, gas gauge also acting funny. the rpm feels like we are in 2 or 3 gear when we are not.
dear friend-it sounds like your vehicle went into limp mode,you can disconnect the battery in order for the ECU to reset,then if the vehicle feels ok then take it for a diagnostic test
Top Blue Computers & Internet Experts
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
vince
Are you a Blue Computer and Internet Expert? Answer questions, earn points and help others
