SOURCE: Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
SOURCE: Canon ir2800 making high pitched squealing noise
change the film aswell......film will last longer if cleaning assembly is changed rountinly
SOURCE: fuji xerox docuprint c3055dx printe
please check the pick up roller on the unit. maybe it is worn out. if so, please replace it.
SOURCE: FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
SOURCE: My Fuji Xerox C525A constantly says that the bypas...
make sure you have the right paper size settings. The paper loaded in the tray might be shorter than the setting in the document. Check also the output size in printer setting.
