SOURCE: RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
SOURCE: volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
SOURCE: Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card,
Lets first make sure your remote is not causing your problem,
Look at the light (led) on the remote, is it lit and pulsing?
If not you are having a problem with the control panel,
Have you recently cleaned your tv with a liquid?
If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: RCA Home Theatre F27202FT won't
Flyback.....# 239111 and HO transistor = 237470
Check the transistor with a multimeter before checking the flyback
SOURCE: tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
