in old model copier you must adjust td sensor after replace developer. in toshiba 161you must: 1.press0and5 in numeral keys 2.turn on machin .aj mode shown 3.inter 200 by numeral keys and start or interput Machin work for minutes . Press interput ana turn off then on
Pls machin off
Now press & hold 2 minutes 4no button+power saver button+stop button press and then machin on showing hdd formet after some time ready to copy your machin
The filter on the spinner pump has become blocked. At the bottom of the machine at the front the panel should come off.There will be a filter to remove and unblock. If in doubt call the manufacturer for a service call.
010-398 Fuser Lock Failure RAP
Description
The Fuser Fan failed.
Power OFF/ON
Procedure
Turn on the power.
Visually check the rotation of the Fuser Fan
