Lavor 160 powerwasher
SOURCE: thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
SOURCE: powerwasher honda 13.0 running fine
If this has the thick silver gas cap, I have had similar problems on a number of these engines because it is a vented fuel cap and it will slow or even stop the fuel flow if they stop venting Try loosening or better yet replacing it. If that doesnt solve it then you may want to drain the fuel and put in fresh fuel Pressure washers will get water in the tank. Also make sure you drain the carb bowl. There is a bolt on the side of the carb bowl for that purpose.
