SOURCE: Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
SOURCE: Own a "Craftsman Rear Tine
Can you move the tines by hand???
They should turn by hand if you try to move them...if not then they are bound up by something...
either a bearing has gone bad, something has wrapped around them, or there is something stuck in there that will not let them turn...check for a rock stuck between one of the tines and the housing around them...
Get the tines moving freely and you will be okay again...
heatman101
