Cycling Logo
R
Rex Wood Posted on May 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Weatherby Orion over and under 12ga shotgun It sometimes fires both barrels at same time What can i do about this THANKS
Jack Levin
Level 2:
Habit-Forming:
  • Expert 113 Answers
  • Posted on Jul 11, 2019
Jack Levin
Expert
Level 2:
Habit-Forming:
Answers
113
Questions
0
Helped
25159
Points
248
Have you considered loading one shell at a time?
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 01, 2010
SOURCE: need to know about my shotgun
You can get some good description info from this site. It may also help you dig further if you need more. hopr this helps
http://en.wikipedia.org/wiki/Winchester_Model_1912
Anonymous
  • 425 Answers
SOURCE: I have an old Mossberg Model 188ke 410 shotgun the
It sound like the firing pin spring has become weak. The simple way to fix it is to replace it, but if you are a handy man, you can remove it and re set it. The down side to this is that it will not last as long as a new part because it has already been weakened (a sort of metal fatigue). I have a similar problem with a very old Anshutz rifle. But sourcing the part is next to impossible. A Gunsmith could make a new spring.
Ben_Trider
  • 5 Answers
  • Posted on Aug 11, 2010
SOURCE: got a remington bicenntenial 870
The Bicentennial 870 was built in a Trap grade, Skeetgrade and a Trade model. They sould for around $225.00 and were made to commemorated the US Bicentenial iin 1976. Current value on this model in a target grade is around $500.00 and around $400.00 for the Trade model.
evanusa
Evan Benson
  • 198 Answers
  • Posted on Jun 10, 2011
SOURCE: i need a parts manual
Here is a list of the original manuals:
http://www.histandard.info/manuals/sears/bashotguns/index.html
Please rate this answer! Thanks!
Anonymous
  • 1285 Answers
  • Posted on Aug 13, 2011
SOURCE: looking for manual on remington
http://www.remington.com/pages/news-and-resources/downloads/owners-manuals.aspx
I have an L C SMITH double barrel 12ga shotgun serial # fw 36102 what year was made?
Local gun shop has reference book that will tell you the needed information
I have a Belgium browning that the serial # that starts with 7x?????, and would like to know the model and manufacture date
Its from a foreign country. You'll be lucky if you find out anything about this gun. Take it to the nearest gun shop for their assistance
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
2helpful
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Can u tell me how to find or figure out the age of my Sweet 16. It was left for me when my dad died and he bought it new before I was born and I am 48 born in 1962. The serial number on my Browning Sweet...
S - 19258-August.
Year is 1925 confirm.
If you want to be more specific and want to know more details. on the month you can call.
You can call Remington at 1-800-243-9700 and go thru the menu selection. One of the menu options is to request information on your Remington based off the serial number. You read off your serial number and the guy looks up in the database the year the gun was made and what the original barrel was for that gun (if gun had barrel options like shotguns do).
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
2helpful
Will not cycle
your shotgun may just need a realy good clean up,,,look in the gas by pass ports in the barrel are they blocked up with crud! clean the piston and cylinder remove all the carbon use very light oil on this part,,strip the action to clean it out of unburnt powder,,,,also they dont like soft rounds,,stick to fast heavy loads,,they love them,, but birds hate them!!!
Top Time Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Time Cycling Expert? Answer questions, earn points and help others
