Get easy steps to forgot or change DELL PRINTER renewal instal
SOURCE: user's guide- trouble shooting and routine maintenance
printer will not print referring me to the trouble shooting and maintenance chapter in the manual which I can't find......I have a Brothers MFC-420cn CAN YOU HELP ME......
SOURCE: Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
Try resetting the purge counter:
1) Enter machine maintenance mode (on MFC240C all fourphoto/copy/fax/scan lights flash in maintenance mode). Care is neededin maintenance mode, otherwise critical settings may be inadvertentlycorrupted.
FAX models with numerical keypads:Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if youfail to complete the correct key sequence within two seconds, press theStop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys.Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenancemode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the loginformation list to reach the purge counter. The purge counter is the25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge
counter is already full. Please refer below for the instructions on troubleshooting
your machine.
1. To enter MAINTENANCE Mode: Press
MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the
following:
a. 8 then
press SET
b. 0 then
press SET
3. Using MONO START, just press it until
the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the
following:
a. 2 then
press SET
b. 7 then
press SET
a. 8 then
press SET
b. 3 then
press SET
This is to reset the purge
counter. Then press stop/exit
5. Using arrow up button look for the
following:
a. 0 then
press SET
b. 1 then
press SET (To reset unit)
a. 9 then
press SET
b. 9 then
press SET (To exit Maintenance mode)
