SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
SOURCE: need a deck belt diagram to a cub cadet 1415 mower
This is one of my gripes with Cub Cadet.
the will not make it easy for you to find the information on the internet. They want you to go to a Cub dealer even if you have to travel 50 miles. And if it is one of the home center versions then the Cub dealer probably will not help you.
good luck.
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
SOURCE: I need a mower deck belt diagram for cub cadet
Go to this website, upper right hand corner and do a parts look up.
Search for your model and that good stuff they ask of you and then
choose mower housing should be there, browse the site it's really cool
and has a lot of info.
http://www.jackssmallengines.com
I did a
sample search for generic riding mower deck and found great diagram of
belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
SOURCE: Cub cadet zrt50 mower deck will not engage
check the fuse then see if there's power to the clutch then check the safety switches
