Question about Golf
Lights and horn will not work on 2011 Zone golf cart
SOURCE:
I965Mstang
  • 24 Answers
SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
Posted on Nov 07, 2009
  • 94 Answers
SOURCE: how do i wire my golf cart for one light and one
The batteries are connected in series (6V + 6V+ 6V +6V +6V +6V), Select only two batteries (CONNECTED TO EACH OTHER in series FROM POSITIVE TO NEGATIVE (last two batteries preferred) and run two wires (one black one red) from the positive (red) and the negative (black). purchase two switches one MOMENTARY PUSH BUTTON AND ONE TOGGLE. Split the two wires by ADDING another length to the middle of each wire respectively Add the switching devices by connecting the red wire to one of the terminals. The other terminal will then receive Another length (red) to be the connected the same way to the horn (push button switch) The black wires (ground) are to be connected to the other terminal of the horn and light. NOTE: it is advisable to add a 15A in line fuse to the red wire near the battery.
Posted on Oct 17, 2011
  • 3 Answers
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Posted on May 15, 2012
  • 34 Answers
SOURCE: I bought a 2010 zone electric cart and it will not run but about 20 minutes on a full charge can anyone help Please
Have the batteries tested using a load meter. Advance and Auto Zone can test them for you. If batteries are 6 years old or older, you will be looking at a new set. A LOAD test is the only way to test.
Posted on Mar 03, 2015
  • 1443 Answers
SOURCE: Why doesn't our Melex golf cart start after replacing batteries.
sounds like you have either a relay or computer that is bad, needs to be serviced
Posted on Dec 01, 2015
My 2009 tomberlin golf cart the lights, horn,turn signals are not working. Every time you put a fuse in it blows instantly
You have a dead short somewhere. Look for insulation off the wires, check to see if all connectors are not touching with space between. Make sure all is clean an look for burn wires an connectors, once I found a dead insect shorting out the connectors.
May 29, 2017 | Golf
2017 Bennche Bighorn 500. Does it have a horn?
It must have as it is road ready with lights, speedo, trip meter etc. Even a golf cart has a horn. The full detailed specs are here, but don't mention the horn. Phone a dealer and ask. It is an easy job to install one if you need to.
2016 Bennche Bighorn 500
Mar 23, 2017 | Cars & Trucks
Wiring diagram for 2010 star
did you check the fuses?
Jun 02, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Nov 30, 2015 | Golf
Check the battery for voltage. May be shot and won't fully charge even though it says it is.
Dec 26, 2014 | Golf
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Nov 07, 2009 | Electronics - Others
Golf Logo
42 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
