SOURCE: Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
SOURCE: How do I set a seth thomas weather station from a
Press and hold the mode button until the year starts flashing in the upper left. Tap the mode button 3 times. You will see "24hr" with the 24 flashing. Press the + or - button on the back. Press the mode button 4 more times (or just leave it alone for about 30 seconds and it will go back to the normal display).
SOURCE: I need to change the atomic clock from military
Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
SOURCE: timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
