Garden Logo
Jared Clark Posted on May 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cub Cadet LT1042. Just bought it with 262 hours. It wasnt running, I found broken wires to the fuel shutoff on the carb. Bought a new carb online (not OEM). Now it will oy start with carm cleaner but then it stays running and runs great. It just will not start on it's own regardless of where the throttle is set or choke. It has a new fuel filter and the diaphragm pump is delivering fuel. Gas is brand new and spark plug is new (though it's not a champion as it calls for)
CJ Rock
Level 3:
  • Cub Cadet Master 4,417 Answers
  • Posted on May 31, 2019
CJ Rock
Cub Cadet Master
Level 3:
Answers
4417
Questions
0
Helped
1642052
Points
14985
Likely it needs valve lash adjustment.
5 Related Answers
Rexter1
  • 40 Answers
  • Posted on Mar 12, 2009
SOURCE: cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Anonymous
  • 10865 Answers
  • Posted on May 10, 2009
SOURCE: cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
Anonymous
  • 957 Answers
  • Posted on Apr 28, 2010
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Anonymous
  • Posted on Apr 30, 2010
SOURCE: my cub cadet mower LT1042 will not start. It acts
Just had the same problem with our LT1042 and it was the fuel shut off soloniod. Could not buy just that piece so we took it off and cut off the piece that went up on the carborator and put it back on. Started right up. Now it back-fires when we shut it off but it runs.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Sep 12, 2010
SOURCE: Starts with choke but will not run when choke is
I've noticed the Echos are cold-blooded and a decent warm-up time is required. You indicate the fuel mixture has to be somewhat rich to keep the engine running. This indicates the needle jets need tweaking to acquire the proper mix (if applicable) or else the fuel pump diaghram is not functioning properly and needs replacement according to the symptoms.
Here is a link to the site that has the G&D (gasket and diaghram) kit and RB (rebuild) kit part numbers for you. You will need to know your machine's model. Link to determine your carb: http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
This is the link to determine the part numbers of the kits. Zama has a great site and informative links:
http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
Please vote on this solution.
2answers
Cub cadet RZT S Runs 15 minutes, gets hot, sputters, quits running. Mower has 200 hours on it
Make sure fuel tank is vented and fuel filter is not full of debris.
If you can create a stable way to hold a spark plug wire aprox. 1/4 in away from plug then watch to see if spark stops just before mower dies.
Fuel pump may be the last option , the only way to check is to T in a pressure gauge with a very low scale. Best way for this is sub in another .
Cub cadet 1000 series
Fuel pump if it has one, gas shutoff valve if it has one, or maybe just the float valve inside the carburetor bowl is stuck closed.
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
8helpful
3answers
2helpful
3answers
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
2008 Cub Cadet LT1042 Won't Start
If there is a fuel cup on the bottom of the carb take it off and clean it out real good. Take the fuel jet out and clean out the little hole by blowing it with air compressor or a real fine wire.The fuel jet is most likely the problem.
1helpful
My cub cadet mower LT1042 will not start. It acts like it wants to, and you can really smell gas too. Has a new battery, starter, and spark plug.
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
