Question about Haier Refrigerators
Haier model HSAO4WNCWW LOUD NOISE WHEN COMPRESSOR STARTS???
    Top Expert:
  • Haier Master
  • 85,161 Answers
Broken compressor isolation mounts maybe.
Posted on May 31, 2019
4 Suggested Answers
SOURCE:
  • 2337 Answers
SOURCE: haier plasma tv model 42hp25bat
It looks like the Ysus board failed on your TV. I just fixed one of these TVs by replacing a hybrid that is found on the Ysus assembly.
You can also buy the whole assembly from this site.
Good Luck.
Posted on Apr 21, 2008
22yooper
  • 828 Answers
SOURCE: Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
Posted on May 16, 2008
  • 8 Answers
SOURCE: the compressor is making a loud noise
If you are sure the noise is coming from the compressor.You need to call a tech. to check the unit out.
Posted on Jan 31, 2012
Noise
There are basically two moving parts, the fan and the compressor. It more then likely is the fan. Be sure the air path is clean and the fan blade does not hit anything. If it is the compressor I would suggest getting a new unit and using that one elsewhere for the short time it has left.
Apr 22, 2014 | Haier 65-Pint Dehumidifier
Is it normall for the motor to be loud?
compressor hums -working clanging not good
Oct 13, 2009 | Haier Refrigerators
Loud nocking sound and hissing
Where do you hear the noise in the condenser?
could be the compressor valves  and the hissing sound could be the relief valve inside the compressor
Sep 24, 2009 | Haier Heating & Cooling
When our refrigerator kicks on, after a minute or two it makes this loud whining, from soft to loud, that lasts about 2 to 3 seconds and does it continually till it kicks off. It's like, Waaaaah, waaaaah,...
This sounds like a compressor that is whining. Or something maybe wrong with the fan motor. You can stop the fan to see if its still there. If it is then its the compressor making the noise.
Sep 13, 2009 | Haier Refrigerators
MAKING A LOUD CLICKING SOUNDS
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Haier 9.1 cu. ft. / 258 liter Upright...
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
Haier wine cooler produces intermittent loud "motor" noises.
Turn the unit around so you can hear the compressor (large black small basketball size unit lower left) if the sound is coming from that then it is probably lost lubrication or just failing. "These usually last forever but.... they do fail. I am not sure if this one (loke mine) has a samll fan. Clarify the noise for use and we can tell you what it is. a constant tapp tap tap fast paced is the compressor going out or out of lub etc. . A ting ting ting may be a fan... Robert-Aptos
Apr 28, 2009 | Haier BC112G Wine Cooler
Loud noise
It is probably a rotary compressor unit.
They tend to make a start up noise.
Some technicians advocate adding a booster starting device to help the compressor start more quickly, thereby reducing startup noise.
Mar 12, 2009 | Heating & Cooling
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Refrigerators Logo
60 people viewed this question
Top Haier Refrigerators Experts
geob91
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
