SOURCE: I have a Maytag dishwasher
you have to power the unit back up and then holld the lock in for three seconds, if ths does not reset it then the console not the control bord needs to be replaced it comes with a new touch pad
SOURCE: 1994 Buick Skylark. Lot of hesitation and jerking, power locks
HI MY NAME IS JUAN:
I HAVE A 93 BUICK SKYLARK CUSTOM
AND I HAD THE SAME HESITATION.
I CHAGED GAS FILTER, AIR FILTER, AND USE SEA FOME IN MY GAS TANK AND USE IT ALSO TO CLEAN THE INTAKE SYSTOM, AND IT HELPED ALOT. TWO MONTHS DOWN THE LINE HADE THE SAME HESITATION AND IT WAS ONE OF THE INISION COIAL PACK WAS NOT GIVING THE ELETRICAL SPARK TO THE PLUG. I CHECK IT BY PULLING THE CABLE OFF THE SPARK PLUG WITH THE CAR RUNNING AND FOUND THE ONE THAT WAS NOT GIVING SPARK. I REPLACED THE PACK FOR THAT CILINDERS PLUG AND THE PROBLEM WAS GONE.
HOPE THIS CAN HELP YOU.
SOURCE: Door lock won't lock/unlock with power button
I would think then, that it has to be a broken wire somewhere. Probably in the door jam of the door that doesn't work, or possibly inbside the door. First thing is to see if you have power back to it. Hook a test light up to the power lock inside the door. When you hit the button at the driver's door, it should light up. It could also be a rod has come apart in the door, or broken. You'll have to remove the inner door panel to investigate.
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
SOURCE: power door lock doesnt work properly, it unlocks but wont lock
Hello, I had a similar problem. I checked the fuses dr unlck
10amp, dr lock 20amp, both fine. However, I finally had no choice and checked
all other fuses and the 15 amp fuse labeled "CTSY" was bad! So, check that fuse.
If a similar problem has happend to you, it could be all you need.
lol
