E20 means problem with drain water phase
Only two things need to be checked:
- Drain pump could be clogged or no power supply (the last means
faulty drain pump, faulty electronic or wiring between drain pump
and electronic.
- Your home drainage system (in the wall) is clogged (This is very
easy to check visually, disconnect the drain hose from your
siphon and put water in some container or in washbasin.)
Dado
SOURCE: machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
SOURCE: washing machine zanussi jet wash
unplug machine turn water off then take water pipe off machine,take machine outside and lay on its back,there is two moters up in the top right off machine looking in the bottom of machine, undo the three pipes and two/three srews take both pumps out undo three screws on the top pump split it and unblock then pup it all back.remember to right down wot you have done to pup it back right,it took me approx half hour to fix mine
SOURCE: How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
SOURCE: filter needs cleaning as water does not empty
I was unable to locate your filter in your machine but if it would help after you clean the filter you could install an inline filter between the valve and the hose. This is an RV filter it just screws on like the hose.
http://www.flowpur.com/html/rv_filters.html
The FP12GKE shows just how easy it is. Any RV filter will work.
Testimonial: "Many thanks "
