Vacuums Logo
Annette Shinsky-Hollis Posted on May 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a BDH2020FLFH vacuum and when you turn it on it will run just a tad and then turn off.
brian kossman
Level 2:
Welcome Back:
Visited the website for 2 consecutive days.
  • Expert 74 Answers
  • Posted on Oct 24, 2019
brian kossman
Expert
Level 2:
Welcome Back:
Answers
74
Questions
0
Helped
78610
Points
101
It is most likely clogged, turning off to protect the motor.
1helpful
I bought a cordless Dyson, three days ago. I have charged it three times. It states that this model has a twenty minute running time. This one runs less than 10 minutes. JU6-US-HEA1415A
If after a few more discharge, charge cycles unit still underperforms then return for exchange or money back. Newer batteries have to be "exercised" a tad before they perform up to specs. And if they say 20 minutes, then hold them to it!!!!!!!!!!!!!!
Nov 28, 2016 • Vacuums
Turn off the brake
If you remove the handle, you will notice there is one larger black Phillips screw under the black plastic strip.
Engage the wheels and loosen that screw.
Slide the lower handle part back and forth and you will notice the wheels will reverse and go forward again.
Find the position where the wheels lock and unlock for you, and tighten that one screw again.
It does not take very much adjustment to make that system engage so do it in small increments.
You will see what I mean when you unlock that screw and slide the lower handle just a tad , but the wheels must be in the engaged position in order to adjust it properly.
Hope this helps!
William R!
Won't turn on stop running in the middle of room.
Mine did the same thing. The electrical cord is loose where it plugs into the machine. When you pull the vacuum into the room it puts just enough strain on the cord to break the electrical connection. Push the plug on the cord firmly into the vacuum.
1helpful
My Hoover windtunnel has very little suction. I have cleaned the entire vacuum. Cleaned filters. My Hepa filter is a little torn, don't know if that could be issue. After cleaning it does suck a tad bit...
Is the belt still intact?
Does it has a wand tool, normally they are connected at the bottom of the machine,if it gets plugged up with gunk, that will greatly reduce your suction.
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Vacuum was running unusually hot recently and then
if it was running hot somethinghas melted together and now wont start must be torn apart to see what has failed most likely the vac motor impellar.
Jan 27, 2010 • Vacuums
My roomba 560 works perfectly for a year. Now works ok, vacuum but the dust stays at the bruches and at the bin. i replace the filter but nothing. Thanks George
You need to decide if the vacuum and brushes are runing or not. For me its easy to determine after its run. If the brushed turn then I have debris in the open part of the collection bin when I pull it off the back, but none if the brushes don't turn. If the vacuum runs then there is dust at the filter, and none if it the vacuum doesn't run.
You can also remove the vacuum/bin and place the roomba on a hard floor and start it and look into the rear and see if the brushes are turning.
When the vacuum is running there is a noticeable amount of air pushed out the rear vent.
When you've figured out what isn't operating, you'll be halfway to solving your problem.
2helpful
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
10helpful
4answers
No steam in scunci steamer will not work lights uop hear pressure and heats up
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
2helpful
2answers
Where can I get a hard copy of manual for Bisell 7920 ProHeatr
Try bissell.com, part number for the owner manual is 2105811. It has 2 belts, one for the pump and a cogged belt for the brush roll. Take off the belt cover on the left side and you can see the flat pump belt, if it looks ok, then turn unit over, remove the red arm retainer, has one screw, then the you can pull the arm loose and off, the cogged belt is there. If not broke, then look at the end of the pump, it is a double pulley, the inner one is for the flat belt, the outer one has a cogged pulley, the cogs may be worn down, or it has broken off, in which case you will have to replace the pump, the pulley comes only with the pump.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
