Computers & Internet Logo
T
Tracy Saegert Posted on May 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am running a slideshow on my View Sonic monitor. The slides are on a USB drive and are number 1-13. The slideshow is playing out of order. How can I fix this?
Larry Ng
Level 3:
Top Expert:
  • Sonic Master 14,598 Answers
  • Posted on May 30, 2019
Larry Ng
Sonic Master
Level 3:
Top Expert:
Answers
14598
Questions
0
Helped
3278563
Points
66615
No slide show application stated, of vast types.
easy has settings why not do that? first.
5 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jul 30, 2007
SOURCE: Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Anonymous
  • 159 Answers
  • Posted on Oct 20, 2008
SOURCE: View Sonic VX910 LCD Monitor - Power Supply Board
I have been repairing them through ebay due to the fact that they are not available to buy right now.
They've been out of stock for what seems like forever !!
bammbammfran
Anonymous
  • Posted on Aug 26, 2009
SOURCE: USB Playback order is wrong
Ive just had the same problem with my Kenwood KDC-W6041U
What has worked for me was to rename the tracks at the beginning of the file name i.e.
01-track
02-track
Not
track-01
track-02
Testimonial: "Thank you so much. This was the problem. I didn't realize the system wanted the number to precede the name. Now I don't have to buy a new radio!!!"
Anonymous
  • Posted on Sep 10, 2009
SOURCE: view sonic -E70fB monitor displaying H.V frequency
view sonic -E70fB monitor displaying H.V frequency out of range
when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
Anonymous
  • 53 Answers
  • Posted on Sep 14, 2009
SOURCE: my view sonic monitor is turned on and then in a
Sounds like overheating of something inside. Open the monitor, get access to PCBs and observe for darkened areas especially over the power supply and inverter. Also that long working before shut down may tell about bad solder junction, also caused by constant local overheating - look for those with tiny cracks, especially over darkened areas on PCBs.
Most likely - that's the source of problem with your monitor. And, as far as you open the monitor, check for any popped electrolytic capacitor - never bad to replace them too.
I have several hundred JPEGs on a thumb drive that I want to play in a continuous loop on the TV through my PlayStation 3. I can get the pictures to display with no problems, but I can't figure out...
plug in your usb device. Now go to photo on your main menu in the ps3, find usb device and hit X, it's going to say digital camera images, now hit the triangle for options, slideshow comes up with start next to it, hit X, then choose what type of slideshow you want(ex: normal, slide, portrait, ect.) hit X and there you go.
I made a powerpoint presentation with PP2003, first added 6 slides, then added another 20. When I add music to the presentation, the music stops at the 6th slide. HELP!
To make a sound continue through multiple or all slides, follow these steps:
  • Go to the slide where you want to begin your audio track (defaulted as the first slide), and select Insert -> Movies and Sounds -> Sound from File to insert the sound.
  • After you click OK, you can see a message pop up asking how you want the sound to start in slide shows. Click Automatically.
  • Select Slide Show ->Custom Animation to enter the Custom Animation pane. Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slideshow if you don't want it appear.
Now you can play the soundtrack from the very beginning to the end of your slideshow.
Source:
http://www.dvd-ppt-slideshow.com/powerpoint-knowledge/sound-across-slides.html
When previewing my video in adobe encore, it looks fine but when i burn to dvd, the video jumps everytime the camera moves. What can i do?
This is everything from adobe encores website.
Playback issues in Adobe Encore DVD 2.0 have a variety of symptoms. The following symptoms may occur when you use the preview feature, when you play video in the Monitor panel, when you play to an external device, or when you edit a menu or slide:
-- Video or audio exhibits stuttered playback.
-- Video or audio cut in and out.
-- Audio is out of sync with video.
-- Video displays as black in the monitor panel or after burned to disc.
-- There are general redraw problems in the user interface.
-- Encore DVD returns the error message, "Invalid requested time," when you transcode a file.
Beginning troubleshooting
1. Test the DVD on a variety of players.
Not all DVD players behave the same way. By testing the DVD on a variety of players, both set-top and software, you can determine if the problem is related to the DVD itself or just the player.
2. Make sure that the system meets the requirements for digital video.
Video may not play correctly if your system doesn't meet the following requirements:
-- Intel Pentium 4, 1.4 GHz processor or faster
-- Windows XP Professional or Home Edition with Service Pack 2
-- 512 MB RAM (1 GB or more recommended)
-- Hard disk with at least 16 GB of space for installation and ongoing work (RAID recommended for HDV/HD editing)
-- 1280 x 1024 or greater color monitor resolution, 32-bit display adapter
-- QuickTime 6.5 required to support import and export of QuickTime files
-- Supported DVD burner *
-- Stereo sound card
* For a list of supported DVD burners, visit the Adobe website at www.adobe.com/products/encore/systemreqs.html.
3. Update video display card drivers.
Outdated or flawed video display card drivers may incorrectly display motion video and textures, or incorrectly report their ability to display motion video or textures to Adobe Encore DVD. Contact the video display card manufacturer for the latest display drivers and driver information.
4. Select an appropriate Playback Quality setting.
You can display playback in the Encore DVD Monitor panel at either High quality, Draft quality, or Automatic quality. By default, the Monitor panel displays video at High quality; that is, it displays all the pixels of each frame of video. When Encore DVD plays back unrendered video at High quality, the video may stutter or ****. When you select Draft quality, Encore DVD always displays video at one-half resolution in the Monitor panel. When Draft quality is selected, playback is smooth but the image quality is affected. When you select Automatic quality for the Monitor panel, Encore DVD dynamically adjusts image resolution between High quality and Draft quality to best address the available system resources.
To choose the Monitor panel playback quality, select File > Preferences > General, and then select an appropriate Playback Quality setting.
5. Deselect the Automatic option in Audio/Video preferences.
1. Choose File > Preferences > Audio/Video Out.
2. Under Video Playback, deselect Automatic.
3. In order for the change in preference to take effect, you must close the Monitor panel and then reopen it.
The Automatic option is selected by default, allowing Encore DVD 2.0 to play video in a Standard Direct3D mode. When it is not selected, video plays in GDI mode.
6. Troubleshoot slideshow playback issues.
Many DVD players, both set-top and software, handle playback of slideshows differently. To conserve disc space, Encore DVD creates an MPEG I frame for each slide then assigns a duration for that frame based on the slide's duration. Many players cannot accurately display these and will instead display only a single frame of the image before reverting to a black screen for the duration of the slide.
If you are experiencing playback issues with your slideshow, be sure to play it back using a variety of players. If you determined that slideshow playback is the issue, then you can try the following workarounds to ensure the slideshow will playback correctly on all players:
Note: The following workarounds will increase the amount of space used on the DVD.
Add zooms or pans to each slide.
When you add a zoom or pan effect to a slide, Encore DVD will render the slide as a video file instead of an MPEG I frame with duration.
Create the slideshow in Premiere Pro.
You can import all of your slides into Premiere Pro and create a slideshow there, then export the file as an AVI, import it into your Encore DVD project, and add it to a timeline.
If you create the slideshow in Premiere Pro, users cannot manually advance through the slideshow the same way they can if it was created with the Encore DVD slideshow editor. However, if you add chapter points for each image, then viewers can skip ahead before the timeline automatically reaches the next image.
Create menus from each slide and link them.
By creating menus from each slide and linking them in the desired sequence, users will have complete control over when they can advance to the next image. You can set up invisible buttons with invisible highlights to give the impression that only the image is on screen, or you can include visible navigation elements for the next and previous slide, as well as any option that is available for a traditional menu.
If you create menus for each slide and link them, then you cannot have a continuous soundtrack playing throughout the slideshow. Menus can have audio but they are specific to each menu and will start from the beginning each time you access a new menu.
Intermediate troubleshooting
7. Optimize hard disks.
Optimize hard disks by defragmenting them, updating their drivers, and configuring the disk drives. These procedures improve playback speed and performance in Encore DVD. For further assistance with these tasks, contact the hardware manufacturer or an authorized repair service facility.
-- Defragment hard disks by running the Disk Defragmenter utility included with Windows or a third-party disk utility such as Symantec Norton Utilities. If you use external (non-system) disks for video, you can reformat them instead. Be aware that formatting erases all information on the disk. For instructions, see Windows Help or the documentation for the utility.
-- Update disk drivers to ensure that they aren't damaged or incompatible with the system. If a disk was formatted with a third-party disk utility, you must use the third-party disk utility for this procedure. For instructions, see the documentation that came with the utility.
8. Test digital video playback in a third-party digital video utility.
Play your video clips in an application other than Encore DVD to try to isolate the problem. If playback is problematic in an application other than Encore DVD, the problem is not with Encore DVD; troubleshoot your system or that video file.
9. Optimize Encore DVD.
For information about optimizing Encore DVD, see the Encore DVD User Guide, Online Help, and document, "Optimize performance of Encore DVD (on Windows XP)."
2helpful
2answers
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
How to use my external USB hard drive
IF you want to back it up
in the above list you made, click view all files in folders
then highlight all the files and to the left it should say Burn To Disk
click on the burn to disk and follow the on screen instructions
Hope this helps
if not write what other trouble it has
Thank you
Fixa fan
6helpful
4answers
No sound VA1912wb
I have the same problem but after much playing around with the monitor controls I found that decreasing the contrast allowed me to hear the sound.... The more I decreased the contrast the better the sound became. To test it have a sound track playing and slide the contrast down (less) til the sound comes on. Mine was sporadic but the more I decreased the contrast the better it became. Ok you electronics engineers - tell me why. One draw back on my monitor is now I have raster lines running down the screen.
Slideshow on axion digital photo frame
noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Why can't I run a Slideshow in Nikon View?
In order to display slideshows in Nikon View the Apple QuickTime software must be installed. QuickTime is installed from the Nikon View CD or can be downloaded, for free, from the Apple Computer web site: http://www.apple.com/quicktime/products/qt/ Quicktime is available for Windows 98, ME, 2000 and XP as well as Apple Mac OS 9 and X. If Apple QuickTime is not installed, when the "Slideshow" button is clicked the computer will "beep" and nothing else will happen. Installing QuickTime and restarting the computer will allow the show to display as desired.
Top Sonic Computers & Internet Experts
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
