SOURCE: unlock volume on jvc tv
I've never really heard of the audio being locked in these units.. I do know there is a back-door code to unlock the channels, just press 8-8-8-8 for that...
It is possible that the auio amp is out, in this unit it's a TB1253an and a simple repair for a shop...
Hope this helps!
Bill
SOURCE: unlock truflat tv without remote?
ok this totally stressed me out but I figured it out and my TV is ON!! I purchased a really cheap universal remote at a .99 cent store. Sat in front of the TV and followed the directions on the manual for my new remote, keep in mind there was a red light lit on the TV, when all directions on connecting the remote with the TV were complete I pressed on and the TV turned on. I hope this helps!!!!!
SOURCE: I lost the remote control of my JVC plasma tv
No.Not a good idea etheir to buy a universal remote control's.Most of the times like 80 to 90% of the times universal remotes dose not have all the functions like the original remote.Try website like Remotes.com to buy an original remote or very close to the original remote.
SOURCE: I would like to know
Hello 1. To use the override code: 2. Hit the MENU key to get to the menus. 3. Go down to the SYSTEM menu and hit the right arrow on the remote control. 4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code. 5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
If your Apex has a Menu button on its front panel you can unlock it by the following method. If not, you must have its remote control handset. To unlock it:
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Ok
SOURCE: Can I unlock my tv Philip plasma tv without remote
Without its remote control, you can't.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
