Hi i have an brother intellfax 775 how do i set this up to receive fax i m not sure thank you for your help
[email protected]
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
well when i try to send a fax it saids poor line condition
it rings then it says pick up call, how do i recieve the documents someone is sending me? [email protected]
