Question about Water Water Heaters
Water system leaking the system is ten years old
    New Friend:
That ;is about the life expectancy of a tank type heater. What specifically is leaking?
Posted on Jun 03, 2019
SOURCE:
I have overall good water pressure until recently now good cold water BUT hot water not so hot and very low pressure?????
It sounds like you have a scale problem which can seriously affect your water flow. If the water heater is older than 10 yrs, then this may be your problem.
If so, try draining the htr. First off, turn your heater off. If electric, turn off 30 amp two-pole breaker in your elec panel. Your elements may also be scaled up, thereby reducing their effectiveness. If you have little hot water, your bottom element and t-stat may be bad. If the electric heater is older than 10 yrs old, then you may want to consider replacing it as the average lifespan of a heater is about ten years. If gas, just turn the control knob all the way down. Attach a garden hose to your heater drain valve. Run the hose outside and open the drain valve with the water supply to the htr still on. This uses water pressure to blow out the scale that is likely clogging the drain valve. Blow it out for ten seconds, and then shut the valve feeding water to the htr.
Shutting the valve creates a vacuum so the draining will slow way down. To speed this up, turn on hot water all around the house. Do not do this with single handle faucets because cold water will cross over. Only the hot on two handle faucets should be opened.
If you don't have any two handle faucets, you can either turn off the water main and open the single handle faucets, or flip the lever up on the relief valve located on top or on the side near the top. Pull it so that it sticks straight out. This locks it in the open position and allows air to enter, and water to exit. Drain until no more water comes out.
Please keep in mind that if your heater is old, the scale may be the only thing keeping it from leaking, and this may expose that leak.
If none of this works, your inlet and/or outlet on the heater may be scaled up. This requires the removal of piping and scraping out the scale. Once again, if the htr is old, (over 10) you may want to consider just replacing it.
GOOD LUCK!
Mar 28, 2018 | Water Water Heaters
Water leak from top of hot water tank ?
Fix overflow system coz it is not working properly.
Jan 27, 2015 | Rheem Richmond 50 Gal LP Gas 6 Year Tall...
How do I fix Hardie hot water system C32 that is hissing and leaking?
get a plumber to replace it . old systems are not efficient nor worth the time and trouble to try and fix. SORRY
Feb 16, 2018 | Water Heaters
Water heater is leaking from the bottom of unit. it is a 20 year old 119 gal mod# dve120 916 what would you recommend we do with these heaters
Any water heater that is leaking from the bottom needs replacement. A 20 year old water heater has given you great service, you are very fortunate.
Jan 06, 2011 | Water Heaters
Black paticles in water
Check your particles with a magnet. If they stick your tank is rusting out and it may still have some warranty left, 5 -to 10 years is about right for a warranty issue. Any why check the particles with a magnet. Any way it is time to replace the heater. Sorry.
Jun 05, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Vaillant echoplus 837, leaking diverter valve
Replace valve or if it has the usual diaphragm inside remove valve and replace washer/diaphragm
To prevent water draining from the whole system, turn off the taps on the heating pipes located just below the boiler AND the cold mains inlet
Mar 08, 2010 | Long Life Water Heaters
Water Heaters Logo
29 people viewed this question
Top Water Heaters Experts
gbob59
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
