Boating Logo
B
Bernie Simkins Posted on May 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Lowrance elite 5 turns on then turns off after 30 seconds?.
jws1013
Level 3:
  • Lowrance Master 1,713 Answers
  • Posted on Jun 05, 2019
jws1013
Lowrance Master
Level 3:
Answers
1713
Questions
Helped
458125
Points
6786
Probably time for a new one. Harsh conditions like on a boat causes the electronics to fail after awhile
1 Related Answer
zcomputerwiz
zcomputerwiz
  • 92 Answers
  • Posted on Jul 19, 2014
SOURCE: My lowrance elite 5 hdi won't go past the "elite
Make sure that your battery is fully charged. Try a hard reset if it still won't start up.
This will erase all user information on the device, so you will have to set it up again.
With the unit off, press and hold the zoom in (+) zoom out (-) and power buttons. Release the buttons when the map displays.
Article Details
Lowrance® Elite FS 9 Fishing System Fish Finder. I have time to time restart?
Question edited for a lot more clarity. All question need FULL 'make model (what it is)'.
Question moved from 'Power Computers' to Lowrance.
Your problem is in the boat. You either have a bad electrical connection, or a bad connection TO the transducer or the transducer itself is faulty. You can return the transducer under warranty or return it for testing. It is unlikely to be the internal memory IMO.
Others report the same issue
https://www.thehulltruth.com/marine-electronics-forum/614638-lowrance-elite-7-hdi-randomly-restarts.html
Have you tried a Hard Reset.
I want a lowrance elite 5 manual
Available on Lowrance we sure for free. View Lowrance elite 5, go to documents, manual and download
The depth finder on my elite 5 Lowrance blinks if I go over 14 mph. And the screen gets very hot after a few minutes of run time?
Hey Robert,
the blinking is usually the result of the transducer losing contact with the water..
As far as the screen getting hot.. that is not good.. do you have this unit mounted in dash? It needs some ~cooling.. just some airflow..
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
My lowrance elite 5m hd wont turn on
It's either a software or processor malfunction. Make Lowrance fix it or make it right by you. 3 in a row all with the same issue means they have a major issue they need to resolve.
Don't take no for an answer. I've seen recurrent problems through the last couple of generations of mid priced 4" & 5" systems.
1helpful
What are the data cable 5 wire used for and where do they get hooked up
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
The manual link below.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Top Lowrance Boating Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
