Question about Water Water Heaters
DHC Instant Tankless Electric Water Heater water is warm how to fix
    Habit-Forming:
    New Friend:
  • 119 Answers
Set temp control!
Posted on Jun 18, 2019
SOURCE:
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
  • 11 Answers
SOURCE: takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
Posted on Jun 20, 2009
  • 244 Answers
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Posted on Nov 01, 2009
  • 68 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
  • 37 Answers
SOURCE: i have the bosch
how is heating element ? Wasit on with no water running thru it. Does it have a reset?
Posted on Jan 26, 2011
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
Stiebel Eltron 221094
Stiebel eltron model 221094 hot water is not as hot as it was before,
only warm water coming through. Do I need to replace unit?
Oct 05, 2013 | Stiebel Eltron DHC 10-2 Electric Tankless...
Hi my heater is making a click click noise,
Don't worry there is nothing wrong with the water heater making a clicking noise, mines does that too.
Thanks
Jun 03, 2011 | Stiebel Eltron DHC 10-2 Electric Tankless...
The safety thermal cut off switch keep cutting off and am not getting any hot water in the shower
There is a short somewhere ... You will have to get the fault fixed so the safety will stay engaged.
Probably not what you wanted to hear.
Apr 05, 2011 | Stiebel Eltron DHC-E 10 Electric Tankless...
Can't get any hot water, tried the breaker, tried unplugging and plugging it back in. Out of options other than calling a plumber in to take a look.
If this is 240V electric tankless, make sure unit is getting 240V.
Circuit can test for electricity if just one leg of 240V circuit is on, but the other leg is not.
http://waterheatertimer.org/240-v-water-heater-circuit.html#120-240
All costs are energy.
Find a plumber trained in that specific brand of tankless.
Read manual completely several times, and make sure maintenance is done on yearly basis.
Read troubleshoot section completely.
Manual should have phone number of manufacturer.
Call manufacturer for name of trained service technician in your area.
Before installing tankless, make sure trained person is available in area.
This will give insurance that tankless can be successfully maintained, and it will help economy since tankless problems can go on, especially as unit ages.
Tankless should be de-limed each year.
Tankless cannot be exposed to more than 11 grains hardness in the water.
Water pressure, water flow, water quality, air quality, air supply, gas supply, venting, internal parts such as filters, washers, circuit board, dripping condensation are all causes of tankless failure and problems can be combination of several factors.
Problems can be simple or complicated.
Install tank type heater as back up for those days when tankless is not working.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/images/Basic-240-Volt-water-heater-circuit.jpg
http://waterheatertimer.org/Tempering-tank.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Stiebel Eltron DHC Instant Tankless...
The water heater "Stiebel Eltron
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the problems associated with your model.
I believe they offer a refund if the 'fix' doesn't work.
The manual might also have troubleshooting.
Each day I see 20-25 unanswered questions about tankless water heaters.
And the day before, there were same number of unanswered questions about tankless products.
The number of questions shows the complexity of the machines, the brand-specific-ness of the problems, and the inability of the manufactures to take care of their customers.
If I understand correctly, the manufacturer will refer you to the installer.
There are not many ways a do-it-yourself-er can fix a tankless.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Oct 30, 2010 | Stiebel Eltron DHC 10-2
How do I light my pottertn kingfisher pilot as its gone out? Keep pusing the ignite button but nothing is happening
Push also the gas button and hold in until pilot lit and then for some seconds [8-30] after until the thermocouple is hot enough to tell the boiler to light the main burner
Dec 16, 2009 | Stiebel Eltron DHC Instant Tankless...
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Water Heaters Logo
Top Water Heaters Experts
Fred Sops
Don Walper
Level 1 Expert
auntyjack
Are you a Water Heater Expert? Answer questions, earn points and help others
