Electrical Supplies Logo
Jennifer Ordway Posted on May 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coleman 6250 generator - Coleman Electrical Supplies
Mai Lor
Level 3:
Genius:
  • Master 2,558 Answers
  • Posted on May 28, 2019
Mai Lor
Master
Level 3:
Genius:
Answers
2558
Questions
0
Helped
525207
Points
7053
What about...? Is it good...? Looking for one or want to sell ?
Good luck
Mai
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Sep 10, 2008
SOURCE: Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Anonymous
  • Posted on Dec 31, 2008
SOURCE: lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
Anonymous
  • 169 Answers
  • Posted on Mar 01, 2009
SOURCE: owners manual
Yes there is, here.
Regards,
Carl
Anonymous
  • Posted on Mar 16, 2009
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Phil Rivera
  • 83 Answers
  • Posted on Apr 02, 2009
SOURCE: three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Wiring diagram of on/off switch. coleman 6250
coleman 6250, AC power generator gas. 10HP WX 6250???
does it matter with 2 pins, no.
I just sold one , last week.
100% perfect.
and have full documents on it. i came with manual new in box and wiring and parts list there, lost the manual did you already?
the one switch on most gens is SPST , 2 PIN SWITCH.
IT JUST KILLS SPARK..
IS THAT THE REAL MODEL # OR JUST WATTS
ALL GENERATORS HAVE TAG AND SHOWS TRUE MODELS#
2helpful
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
1helpful
Coleman 6250 ,no power generated
check your AVR card...if the brushes are fine...
3helpful
2answers
Coleman 6250 Generator won't turn over
try removing the air filter and try starting if it dirty or to oily , no vacuum is created to pull the fuel into the carb
2helpful
Three year old coleman 5000/6250 generator. High
3answers
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
