Question about Water Water Heaters
I want to use a water filtration system on my vitapur water cooler. How do I take out the piercer
The plug on the filtration system got wet. The filtration system works but the plug doesn't.
surprised it didnt trip the main board switch
water and electricity do not mix
hair dryer to the plug
dry plug with rag or paper towel
or wait for plug to dry out
if no better replace the plug
Jul 08, 2016 | Water Heaters
Purchasing a water filtration system for a house
This is very location dependant. Different parts of the country have different needs. I suggest that you contact 3-4 companies and have them submit proposals. They should take a sample of your water, analize it, and then make a reccomendation based on your needs.
Apr 15, 2014 | Water Heaters
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
I HAVE A G.E. SMART WATER COOLER THAT LEAKS WATER FROM UNDER BOTTOM BASE I HAVE TO KEEP A TOWEL ON THE FLOOR UNTIL ITS GETS SOAKED THEN I CHANGE IT, USUALLY OVERNIGHT, I'M USING A 5 GAL. BOTTLE...
try replacing the bottle...it might have a hairline crack that is causing the "leak". I have the same cooler and had the same issue...replaced the bottle and all was well then.
Roy Martinez
Jan 12, 2011 | General Electric GE SmartWater Household...
Water pressure gets very low . GE GNWH38F FILTRATION SYSTEM. HELP !
This generally indicates the outlet manifold on softener is partially plugged. This needs to be removed and either cleaned or replaced.
RJ
Sep 17, 2010 | General Electric GE SmartWater Household...
MY GE SMART WATER FILTRATION HAS A DRIP ON THE
If it is coming from the canister, pull it off, check the o-ring, it is probably pinched. It will need to be replaced.
RJ
Mar 29, 2010 | General Electric GE SmartWater Household...
My GE Filtration system tank does not fill up with water .. The connections look fine
Try loosening the lid .Allow the water to run when the tank is full of water tighten the lid.I beleave your air locked Hope this works for you.
Dec 02, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
24 people viewed this question
Top Water Heaters Experts
gbob59
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
