Re: Lg g6 How do I get the color turned back on to my...
Your have to go into the Settings menu - you have accidentally turned it to grayscale. On my Lg GPad that is easy to do with a side button which I always forget isn't the power or volume ones!
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Your hair is turning green because your missing red when you color your hair. Gray is uncolored hair and to get to a dark chocolate brown you need to add a little red to the color to make up for this. You don't need to strip it out.
Have you heard of people using purple shampoo to neutralize the yellow tones of their blonde? Red will neutralize the green tones, so adding a little red to your color will do this for you.
Gray hair is resistant to accept color.....You might try to find one of 2 products: " Zotos Porosity Equalizer" from Sally's or any beauty supply store. Also, Clairol has a new formulation called "Gray Solution", where there is a cream added to gray hair prior to adding color. This is for next time you plan to color.
In the meantime, you may want to purchase Roux Fanci-Full Color Styling Mousse in either #19 or
#18 to tone down the red tones from your local beauty supply or online.Good Luck
Based on this page, front speaker wiring are:
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
