SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
SOURCE: Poor suction-need to know how
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
SOURCE: bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
SOURCE: My Bissell cleanview is NOT suctioning well, all
did u check the filter above the dirt cup?
twist the yellow piece and wash the filter
SOURCE: No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
