SOURCE: COMPAQ EVO N400C WIRELESS CONNECTION PROBLEM
have done as advised in network adapters the following is what is listed;
INTEL(R) PRO/100P MOBILE ADAPTER
PCMCIA ADAPTER
TEXAS INSTRUMENTS
PCI-1211 CARDBUS CONTROLLER
none have a ? mark or x next to them windows says these are working properly.
can you tell me what button is fn? as i only have f1 - f12?
thank you very much for the time you are taking to help me.
SOURCE: New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
smeags.
SOURCE: WIRELESS PCI 54M G NETWORK LAN ADAPTER CARD 802.11 b/g INSTALLATION
try to unplug it all modem roughter then modem roughter computer on see if its working do repair also thx nick
SOURCE: USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
SOURCE: "Weak or No Signal" message on Samsung 26" LCD TV
I pressed mute on my television and about 5 minutes later it said weak or no signal.What do I do?
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
