Question about Polaroid Televison & Video
How to remove the back of a polaroid ss dv 2811-L1 tv?
This is a 28" hd ready led tv and there are only 4 screws in the back cover along the bottom but this does not release the sides and the top. Does anyone now how to get the back off as I think it needs a new power input board as it is usually difficult to turn on.
SOURCE:
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
SOURCE: Need use New HD PC Monitor with DVI/VGA inputs like HD Ready TV
you need to get a lcd tv device such as from dany or xpod.  it will connect your cable, and its output can be fed into the lcd monitor.
Posted on Jan 01, 2009
MNfisherman
  • 11896 Answers
SOURCE: how do i remove back cover on Polaroid FLM-153B flat screen tv?
REMOVE ALL SCREWS AND BACK PANEL WILL SLIDE BACK OFF
Posted on Feb 01, 2009
mdavinci
  • 20 Answers
SOURCE: CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Posted on Mar 18, 2009
  • 1527 Answers
SOURCE: Need code for polaroid tv tried code 2811 as shown on back of tv but no luck help
hi try 1234
or 0000 thanks
shaun
Posted on Feb 20, 2017
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
Where is lamp location in polaroid 32 in hd tv
I'm not sure which TV you have. The Philips 50' plasma does not have a backlight. The Polaroid 32 can have a incandescent or a florescent backlight. The backlight is accessed by removing the back of the TV and replacing the lamps. There can be 1-4 of these light for florescent and 1-*** number of lights if incandescent, depends on the design, model, features, price point.
Aug 03, 2012 | Philips 50PF9956 50 in. HD-Ready Plasma...
LVM-37w1 after 5 minutes of viewing, picture and sound go off. Blue power light turns orange. attempts to turn on TV are unsuccessful. Blue light immediately turns orange.
I saw this fix posted on another blog by a fellow named Patrick. I tried it today and it it worked. It fixed my Westinghouse lvm-37w1. Basically disassemble the back of the TV (removing all the screws on the edges and middle). Remove screws holding bottom speaker and stand. There are 2 chrome rods extending down. There are small screws inside holding them on. You can turn the rods and unscrew the screws but need a small screw driver to put them back on. Remove the black cover on the back. remove the plates on the lower middle section. You will expose a printed circuit card. unplug wires and unscrew 4 screws holding it in. Remove it, turn it upside down and inspect the solder joints near the lower middle (especially under the gray relay on the other side). I found 4 solder joints that were cracked. Resolder the larger solder joints that are cracked or look bad (small solder joints are too delicate). Put it back to gether and it should work now. Mine works great. No more black screen with no sound.12_2_2011_5_11_21_am.jpg
Sep 29, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Polaroid TLX-01911C LCD TV How do you remove the back? only find two screws located at bottom.
There are snaps at the bottom corners and along the sides. a flat head screwdriver worked for me by prying gently.
Sep 18, 2010 | Polaroid TLX-01911C LCD TV
Polaroid 4241-TLXB wont stay on
I think I may have just solved this issue. Remove the back covers and turn the tv on until it the screen goes black. There will be a little red led that will light up when the screen goes black. right above that light there is 4 little swiches, the bottom one is labled BURN. Switch that one to the opposite direction. I don't know how but mine has been working for a couple days now with no issues. GOOD LUCK!
Jul 05, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Jun 12, 2009 | Polaroid FLM-2632 Television
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
How to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Sep 13, 2008 | Polaroid TLA-01911C TV
Remove back panel
You have to remove the base at the bottom (4 screws), all the screws on the back, then use a thin flat-head screwdriver or other thin brybar and work around the back panel unlatching the snaps that are in place.
After the back cover is off, the metal cover over the board and power supply can be removed by removing the screws around the outside lip of the cover, along with the screws on the bottom and right hand lip of the raised area in the back.
Hope this helps.
Dec 06, 2007 | ViewSonic N3251w 32 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
