SOURCE: Intermittent starting fault on 1994 Yamaha XV1100
Starter motor bearings or brushes are sticking. Strip and overhaul.
SOURCE: my number 9 button isnt working
sir check keypad whether that is properly fitted o not.............
SOURCE: back door on a vw transporter. intermittent fault
I didn,t have a honda civic problem it,s a VWtransporter fault ! You obviously have a fault on your site.
SOURCE: select & skip forward buttons no longer work on the #2 UHF remote
THis solution depends on your ability to do it yourself.
If you are brave enough you can disassemble your remote and dust the black blisterpads with graphite powder being careful to blow off any residue before reattaching. This will add some life to that old remote, but eventually all things must be replaced. Graphite powder can usually be found at most office supply houses and some Schools. It is usually used to lubricate slide rules.
SOURCE: Hi, I have a 585 perspective treadmill. Sometimes
1) adjust the REED swtich, clean it, and tight the connector well , see the diagram attached.
2) try after you fix it, RUN the software calibration go under the HOOD the motor with the instruc for to follow the step in s. calibration
God bless you
