The wireing on the troy built and the wiring on the briggs 20 hp turbo cooled have diffrent color wire ing and i need to know what color wires go together to make it run start and charge the battery and work the deck
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
SOURCE: Hello I have a coleman
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
SOURCE: need color codes for new radio to 99 nissan sentra
Hello jmartinatl,
The color codes for your receiver is here.
Just match the function of each wire the the appropriate wire on your vehicle. Or better yet, purchase a vehicle specific aftermarket wiring harness that plugs into the vehicle wiring.
Hope this helps.
SOURCE: dog ate my wiring on my troy-bilt lawn tracter
Hi you should be able to look it up on this site its called pats small engines
SOURCE: I need help I don't know what color wires go to
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
