I used a LCF touch room controller RC, which freezed. That means that the RC become inoperable from it's touchscreen/from distance! The main problem is that the RC remembers the last command, and if freezes with it, than that could mean the heat will increase, or the lights are on forever. I resolved this situation only by cutting the power supply, and I don not know what could be the reason for this. Yes, there are more RC's connected together, and yes, all of them freezed down. I've added a resistance to, but no effect. PS: they freeze aprox. once in 3 weeks...
SOURCE: Mute button freezes my computer
If its a laptop and it came with vista, its most likely XP isnt compatible witht the hardware do to that it was designed for VISTA.
Try going to the laptop companies website and searching for drivers for it that are XP instead of vista and install them.
You bassically downgraded the machine so XP doesnt know how to use your hardware till you install XP drivers for it.
Good Luck
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
SOURCE: LG enV Touch freezes up intermitantly
if its still under the first year it should still be under covered by the manufacturer warranty. Call 611 on your phone and complain, they (Verizon) should off to replace it.
SOURCE: My Samsung F480 keeps freezing and/or lagging.
I've been having the same issue from past couple of days with no cure but an hour ago I encountered this webpage with a solute. My phones been working fine from past 1 hour. Try this, 1st enter this code *2767*3855# after your phone restarts if it works properly don't proceed to the other step (for me it didn't work the next step did the trick). After this you deactivate your network lock by entering this #7465625*638*00000000#
To be honest I don't find the link between the software issue and network but hey it did work for me and i'm thankful, Good luck. I really hope the lad dies for good and quits haunting me. Anyways, If you need to get in touch this is my email [email protected]. Regards. *grins*
