SOURCE: xantrex power inverter 1750
Sir ,
one of the ic or resistor will be damaged inside ,so kindly replace it,it will be alright.
SOURCE: samsung smh7150 shuts down after a few minutes.
If the mag overheats because its not being cooled it will shut down until its cool.
If the fan is turning slow you can try oiling it but it likely needs replacing.
Another thing that causes this is that the exaust port is blocked because its upagainst the wall and the hot air can not escape.
SOURCE: RUUD Acheivers Series AC unit
The reset is two pins on the defrost board. Put a flat scredriver across them to reset the board.
SOURCE: no signal to monitor, fans run full speed
maybe your cpu is faulty or ... maybe power suply ??
