The new plugs on appliances seem to be thinner than they used to be, and I have seen new appliances in older homes barely stay plugged in and sometimes fall out. If this has happened at your house, the plug in the recepticle does not make full good contact and the small gap acts like a resister and produces heat and can burn out if left installed and can cause a wall fire.
If this is the case, you may need to replace all the recepticle s in your home. I have a home built in 1978 and had to replace all the recepticles because the plugs would not stay plugged in and causing just what you described.
SOURCE: MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
SOURCE: cool touch t-fal deep fryer
My Cool Touch won't come on either. I wiggled the magnetic power cord and it came on one time but then, the second time, I tried wiggling the cord to relenquish the problem and zilch! Becoming more and more frustrated and since my fish was battered and ready to go I started pressing at the connections. It turned out that PUSHING THE POWER SWITH TO 'ON' AND THEN APPLYING FIRMER PRESSURE IN THAT SAME DIRECTION made the light come on, signifying POWER!!! Hope this helps. I imagine that there is some type of connection from the 'ON' switch that just doesn't connect and by pushing the 'ON' button firmly upwards the connection is made.
SOURCE: capacitor burned out? horrible burnt smell.
YOUR GOING TO NEED A NEW MICROWAVE . the cap may be bad but the real bad smell you have is most likely the HV tranformer , if the magntron shorts to ground there will be a small smell if you dont pick up on that and your microwave is set to run another few mins the transformer will overheat and burn , then the fuse blows and the controls shut down . the end result , you have more parts bad than you have good . if you google " GE SPACEMAKER MICROWAVE FIRE ' you will see your not the only one , its getting to be COMMON . good luck
SOURCE: I need a power cord for T-Fal Maxi-Fry Deep Fryer
These two websites sell T-Fal parts:
http://www.thegourmetdepotco.com/store/store_partaccess_index.asp?ManufacturerID=26&CategoryID=32
http://www.smallappliance.com/department.asp?cur=USD&cam=drg_247-10231&sid=18956&mid=32&gid=18963&shopBy=Brand
I also found a few on Amazon.com:
http://www.amazon.com/s/ref=nb_ss_hg?url=search-alias%3Dgarden&field-keywords=t-fal+deep+fryer+power+cord&x=0&y=0
Hope this helps!
SOURCE: Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
