Toshiba 57H81 57" Rear Projection Television Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a rectangular black box across the screen - it goes away when I use the favorite button and have multi screens showing - it returns when I close out the favorites. Color, sound, picture quality are all fine. Just can't get rid of this black box.
Anonymous
Level 3:
Top Expert:
  • Toshiba Master 14,553 Answers
  • Posted on Aug 07, 2009
Anonymous
Toshiba Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2717724
Points
48227
In the customer menu--find the closed caption settings---you will most likely find the set has been set to TEXT 1---with the remote select either CC1 or OFF---the black box was for text (books) and was not ever used much---usually someone engages it by accident
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
5helpful
2answers
Intermittantly there is a black rectangular box that appears on the screen for a few seconds then goes away. Our set is 4 years old. Kris 317-201-6643
Turn off close caption in tv, need to go to menu to turn off close caption function, that will solve your black rectangular box problem.
3helpful
A black rectangular black screen shows up but..... sony trinitron
Check the set up. You may have closed captioning turned on which will show up as a black box if there is no closed captioning information for the selected channel. If that fails to resolve the problem, update this.
Thanks,
Dan
Black box on screen
You have the closed caption on.You need to press the CC button on the remote until it goes away.Thank You very much!
Tyler
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
7helpful
Problem with black box appearing on tv screen
Check to see if close caption is enabled, on remote, press menu, see if there is setting.
Big black box on screen
It has something to do with the closed captioning. He must have hit the closed caption button on your remote. You need to either turn the closed caption off or make another selection under closed captioning like cc1 cc2. Just keep making selections until the box goes away.
2answers
Rectangular Black Box Covers Lower Half of the Screen
I found this because I"m having the EXACT same problem with my DVD. Very frustrating that nothing works....
JVC Screen problem
using your remote ,off the close caption. the black rectangular box that you see for the message but since you have message in the box. that why you see a rectangular black screen.
7helpful
3answers
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
