Question about Timex Watches
I have a Timex Expedition watch. Last night I accidentally kept the stopwatch on, and as a result it isn't beeping or chiming and the alarm is not going off. I've done everything from loosening the back plate to pressing the back really hard. What can I do to fix it without sending it to Timex?
SOURCE:
  • 3 Answers
SOURCE: setting tha alarm
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
Posted on Aug 18, 2008
escapement
  • 2338 Answers
SOURCE: Timex Expedition watch beeping continuously please solve
Try to get solution here:
http://www.timex.com/gp/node/n/255235011/190-2521384-6105829?ie=UTF8&timexBrand=core
Rate, please.
Posted on Jul 23, 2009
escapement
  • 2338 Answers
SOURCE: how dose the chime work on a timex watch
Try to find solution here:
Rate me, please.
  • 110 Answers
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Posted on Dec 06, 2009
escapement
  • 2338 Answers
SOURCE: setting a 1440
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please
Posted on Mar 15, 2010
I changed the battery in my timex expedition watch, and now the alarm doesn't sound. The watch is set for Beep ON, but it never beeps.
Same thing happened to me, took watch to watch shop, they changed the battery and the chimes stopped working. Simple fix, the faceplate was put back on wrong. Unscrew the face plate and turn it upside down (or right side up depending on your POV) the circle on the inside of the faceplate will line up with the springs inside the watch and the chimes will start working again. If you have a pair of eyeglasses screw drivers, like I did, you can do this yourself.
Feb 12, 2011 | Watches
How do i stop the chime on the hour with a Timex marathon stopwatch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
http://assets.timex.com/user_guides/W15_M774/W15_M774_NA_EN.pdf ??
Feb 08, 2011 | Timex T5G811 Marathon Stopwatch
Can't turn off the alarm on a timex Expedition Watch
buy a Casio wrist watch at KMart for around $17.00. They last five years, then the
band breaks and you buy a new watch. I timed the traffic signal system of our city for 20 years from a Casio wrist watch. Now in retirement, I have a Time Expedition which has several alarms which I do not need, and can't turn off. We change the time twice annually, so having alarms and chimes go off without warning ca bve a nuisance.I found some instructions on a website which shows how to turn the alarms off.
Jun 02, 2010 | Timex T41091 Expedition Watch
How do i set the hourly chime on the timex ironman flix watch?
Press Mode till you are in Alarm setting
Press and hold split/start button till you hear the double beep. You should also see a small clock icon above the last digit of the seconds... you are all set. Repeat to deactivate hourly chime.
Nov 12, 2009 | Timex Ironman Flix 100 Lap Unisex Watch
I recently had my battery changed on a timex expedition adventure tech altimeter watch, now the chime doesn't work and the alarm doesn't beep. Please help. Thank you.
You can attempt to have the circuit board reset if it has an "AC". This may or may not fix the problem. Usually when a sound board goes out you have to replace the whole circuit board or movement.
Sep 14, 2009 | Timex Expedition Adventure Tech Altimeter...
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
Setting tha alarm
Dec 21, 2007 | Timex Expedition 40141 Wristwatch
Watches Logo
61 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
pacdave
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
