Manual for Printshop Professional 4.0 - Computers & Internet
  • Computers & ... Master
  • 9,787 Answers
SOURCE:
Installed printshop 2.0 on windows 7 professional. When I open the program and click to start a new project, it automatically pops up not responding. The computer screen turns white and locks up.
Does the Print Shop software say specifically it is compatible with windows 7 and up? if not it will not run, XP and earlier is not compatible with Windows 7 and up as I said..
Oct 26, 2016 | Computers & Internet
How do I get my Printshop to come up without downloading it again?
Something is not quite right with the program, have you tried running in admin mode
Jan 04, 2015 | Broderbund PrintShop Design Suite...
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
New computer has Windows 7. What version works on Windows 7?
Older programs can usually be run in Windows 7 using compatibility mode.
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Mar 04, 2011 | Broderbund PrintShop Signature Greetings...
Printshop 20 deluxe will not install on computor has windows 7
Yes, it will NOT work on Vista or Windows 7. I had to upgrade to PS 23 on my computer. If you have 7 Professional or Ultimate, it is backwards compatible to accomodate older software. If you have Home Premium, it will NOT work on 7.
Good Luck.
Jan 03, 2011 | Broderbund The Print Shop 20 Deluxe for PC
Bought new computer. Cannot download my printshop
You might be trying to loading a 32 bit software packege to a 64 bit operating system. See it the store has a 64 bit version. Or you could upgrade the OS with the microsoft pro packege.
Thanks
Feb 20, 2010 | Broderbund Print Shop Deluxe Version 22...
Program "Printshop CD Label Creator
the problem will solve after registration. go to the printshop web site and register your product.
Nov 26, 2008 | Computers & Internet
Install Printshop V.5 on a computer using Vista
The Printshop V5 program is supposed to run with Windows 98 or Me, therefore in order to use it with Vista or XP, you should open it using Compatibility mode--> Right click on the program icon--> properties-->Compatibility--> select Windows 98 or Windows Me
Oct 31, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
20 people viewed this question
Alun Cox
