Question about Miscellaneous
2005 Yamaha fx1100 waverunner Warning check engine light comes on when accelerating? No light at idle.
SOURCE:
Technopro
  • 243 Answers
SOURCE: stops accelerating and check engine light comes on
The check engine light indicates a fault in the engine management systems. Your car has stopped accelerating because it is locked in fail safe mode and normally you should be able to accelerate just enough to limp to the dealer where they wil scan the computer.
Cheers.
Posted on Nov 09, 2008
  • 6 Answers
SOURCE: no acceleration,audi 1.8t,runs like no boost
have you tried cleaning out the throttle body as i had a similar problem and this worked
Posted on Nov 29, 2008
  • 76 Answers
SOURCE: engine warning light has come on
you need to have the trouble codes checked with a obd2 code reader.
it could be the throttle postion sensor if the car would not accelerate but there is no way to tell for sure until you see what trouble code the vehicle is throwing. most auto parts stores will check them for free. hope this helps
Posted on Mar 21, 2009
countrysi248
  • 443 Answers
SOURCE: rough idle, backfire on acceleration
check everything you can under the hood your air intake system all of it especially make sure all clamps are tight .. and make sure all vacuum hoses are good and not cracking or broken or just loose . you might run a little fuel cleaner through a tank of gas too cleaning the engine fuel system up some. just a few ideas.. Jerry
Posted on Apr 12, 2009
SOURCE: suddenly had no acceleration, check engine light
I had the same thing happen. It was a bad acceleration sensor. Took it to the dealer and they fixed it under warranty.
Posted on Aug 31, 2009
What causes the "Reduced Engine Power", "Service Stability Control" and "Traction Control" warning lights to come on?
the "Reduced Engine Power", problem causes the PCM to disable "Service Stability Control" and "Traction Control" turning on the warning lights to come on for those systems . The reduced engine power is because of a problem with the electronic throttle control system or as GM calls it TAC system . Reduced Engine Power Mode
When the PCM detects a condition with the TAC system, the PCM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The PCM will continue to use the accelerator pedal for throttle control, however, the vehicle acceleration is limited.
• Limited throttle mode--The PCM will continue to use the accelerator pedal for throttle control, however, the maximum throttle opening is limited.
• Throttle default mode--The PCM will turn OFF the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The PCM will perform the following actions:
- Limit engine speed to idle by positioning the TP, or by controlling the fuel and spark if the throttle is turned OFF.
- Ignore the accelerator pedal input.
• Engine shutdown mode--The PCM will disable fuel and de-energize the throttle actuator.
© 2017 General Motors Corporation. All rights reserved.
Drive by Wire training Your best bet , take it to a GM dealer
Mar 04, 2017 | 2005 Pontiac Grand Prix GT
I have a 2005 volvo xc90 t6 that is jerking when accelerating and in idle. It doesn't so it every time but is steadily increasing and began about 2 weeks ago. Check engine light will blink when on...
A blinking check engine light is the warning of an engine misfire that can cause damage to the catalytic converter. Check car by diagnostic tool and keep car well.
Oct 30, 2012 | Cars & Trucks
Warning and oil lights come on at 6000rpm
check wire connections are clean and check the oil sencer !
Jul 05, 2012 | Yamaha Boating
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
May 15, 2009 | Yamaha 12V Air Pump
No acceleration,audi 1.8t,runs like no boost
Nov 29, 2008 | 2005 Audi A3
Miscellaneous Logo
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
