SOURCE: Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
While the freezer is cold, cut out defrost thermostat and measure
resistance, if open, replace, if it's ok check defrost heater.
Temporarily
short the wires that went to the defrost thermostat and now force
defrost.
If no defrost, you have a bad adaptive defrost board.
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
This problem seems to be two sided. A refrigerator
defrost it is supposed to take the water from defrost down a pipe located
behind the freezer rear wall to a pan below the refrigerator where there is a
fan blowing warm air over the water to evaporate back into your home or
business. If that drain is blocked your refrigerator will accumulate a large
block of ice and frost behind the rear panel of freezer and temperatures will
warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let
me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
