Question about Golf
I have a 4 wheel tourtrek golf push cart and its pulling to the right . how do I adjust it?
SOURCE:
  • 34 Answers
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
KAComstock
  • 274 Answers
SOURCE: 2000 golf cart replace dash
A steering wheel puller. They sell them at auto parts stores.
Posted on Apr 25, 2011
emissionwiz
  • 85206 Answers
SOURCE: just bought this j1184 ez
We have no manuals for this type of product. You will need to contact the manufacturer (you don't say who that is) to see if parts are still available. Also we can't cross serial numbers over.
Posted on May 12, 2011
  • 3 Answers
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Posted on May 15, 2012
  • 40 Answers
SOURCE: I have an ezgo golf cart that runs without pedal
Change the stop pedal wires over to the excellerator and visa versa
Someone must have a vrewed up when servicing it
Also contact your golf buggy specialists to confirm its not a mother board or the wires are worn through and earthing out good luck
Posted on Apr 13, 2014
What is the right air pressure for sun mountain golf cart
8.What is the recommended tire pressure for the Speed Cart pneumatic tires?
The recommended tire pressure is 30 psi.
FAQ ' Customer Care - Sun Mountain
https://shop.sunmountain.com/faq.html
You may also purchase products directly from any of the preferred internet retailers or shop.sunmountain.com. ... If the tire pressure checks out and you have a cart outfitted with bungee cords or strapless bag bag bracket you can adjust the alignment by following the instructions in your user's guide. If you have an older cart ...
[PDF]Speed Cart® SVl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/SV1_UserGuide.pdf are perfect for balls, tees, snacks and keys. • Mesh headcover tray. accessories include the. Speed Paq and. Umbrella. • Ergonomically designed to push without straining your shoulders or back. • Large diameter f tires are maintenance free. I. • The E-Z Latch System / makes folding and unfolding the cart simple.
[PDF]Speed Cart® V2 User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V2SpeedCartUserGuide.pdf Speed Cart® V2. User's Guide. To take full advantage of the ergonomic features of your new Sun Mountain. Speed Cart, please read the following information. ... on the side of the brackets, place your golf bag on the cart and retighten the thumb ... your manual brake is not holding, first check the tire pressure on the front.
[PDF]Speed Cart Vl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V1SpeedCartUserGuide.pdf *Reverse these steps to fold and store your Speed Cart. STEP FOUR: STEERING. To steer your Speed Cart push down on the handle so the front wheel lifts slightly off the ground. Then pivot tight or left to change direction, lower the front wheel and go. When adjusting the handle or folding the cart, please note that the tires.
sun mountain golf cart tire pressure Google Search
Mar 12, 2018 | Golf
I need to download usb driver, application and User manual for my TourTrek t11 Golf gPS. It has never been used.
Fixya does not supply software. For a manual, try Googling (TourTrek)(t11)(manual) without parens.
Jul 26, 2017 | GPS
How to fix accelerator that doesn't come back off. When you push on it you have to pull it back off. On cub car golf cart.
Probably a broken return spring or just corrosion. You would have to get under the cart to see if this is the DS model. If it's the precedent model, It is one unit in the floorboard.
Mar 18, 2017 | Golf
Ez-go golf gas cart only runs when rear wheels are off the gound, why?
It has a level switch that is broken or out of adjustment
May 17, 2014 | 1993 Acura Vigor
How do I align the front wheel of the Bag Boy DLX push cart?
Unfortunately, there is no adjustment on the wheels of the DLX. However, you can often adjust it's alignment by ensuring that the weight of the golf bag is properly centered on the cart.
Aug 17, 2013 | Bag Boy Bagboy Express DLX Push Carts
Golf Logo
66 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
