My shredder works in reverse but not on auto. It is not jammed with paper.
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
SOURCE: Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
SOURCE: CD shredder jammed with small CD pieces
If you are able to remove the top. It is easy. Usually 4 screw to remove the top. Be careful with the short cable connecting to the board. Open it up pressure clean the entire unt and especially the sensors top and bottom.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
