Freezer is not defrosting and I want to change cycle to check the heating element.
SOURCE: Is the Defrost Heating Element Defective?
no not at all, it it was bad wouldnt glow at all. and the fact its glowing tells me yes timer and thermo are good.doesnt sound like your having a defrost problem at all
SOURCE: freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
SOURCE: Problem auto defrost refrigerator
i have a refr. G.e TFG27PF Profile and have some bad smell like a wire short. i looke all ever and it looks ok and the refri. is working ok. today sudenlly the DF light started to blink what is the problem/ thank you for a fast answer.
SOURCE: defrost not working
Remove the rear panel on the freezer wall. Advance the timer to see if the defrost heater comes on. If the heater does not come on, locate the defrost thermostat which clips onto the coil near the top of the coil. It has two wires going to it. Unplug the frig and cut the wires from the defrost thermostat and join them together and plug the frig back in. Observe to see if the defrost heater comes on. If the heater comes on now, replace the defrost heater.
