I need model # for my cub cadet with a Kawasaki FH430V 15.0 engine and a 42 mower deck. it's been painted so I have no idea what model i have. Please help
Https://www.partstree.com/parts/cub-cadet/mowers-wide-area-walk-behind-lawn-mower/ See if any of these look right.
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch.
Good luck! Please rate my answer if helpful, thanks.
SOURCE: Where can I find a wiring diagram for a cub cadet lawn tractor LTX1040 2010 model?
Hope this helps.
SOURCE: Noisey Cub Cadet mower
if you geting a humming sound try greasing the pullys and if this donot work, check the pullys for movement, you will feel the one that is bad.
